Calculate difference between 2 values (Formula)
Is there a way to tell AutoCAD to show the difference between 2 values?
I've a block that shows the slope between 2 floor levels, those levels can be + or -.
Is there any way to show the distance between those numbers?
-X +Y
-X -Y
+X -Y
+X +Y
In Excel I'd use the formula IF((X-Y)<=0,Y-X,X-Y), but i'm not sure how to add this in a FIELD
In these
imadHabash
you may try this one . >> Click <<
Imad Habash
j.palmeL29YX
Where are the both values coming from?
Maybe  abs(x-y)  will help you?
cadder
Jürgen Palme
Kent1Cooper
That is, in proper AutoLisp format:  (abs (- x y))
Kent Cooper, AIA
You guys are the best!!!!
Worked as intended. Thanks you!!
Edit: The final formula is: ((abs(X-Y))/Length)*100
