AutoCAD Forum
CAD turning lines joining to objects and other lines without command
1 REPLY 1
BrianAER
236 Views, 1 Reply
demonstration:  a coworker drew a line on top of a W-shape block from endpoint to endpoint of the flange.  when he goes to move the line 1/2" from the flange, the command picks the line, the w-shape, and a beam on top of that.
I cross sectioned the line and tried moving it and it still selected the w-shape and beam.
it's as if when he draws everything is constrained or turned into polylines or blocks or families. I've never seen this before so i dont what could cause this.
he has to explode eveything anytime he has to move a line or object.
1 REPLY 1
Patchy
in reply to: BrianAER
Probably the INFER button is clicked ON, use
_DelConstraint, all and delete them.
”Boost
