Cad layers together with cnc
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello!!
My name is Markku and i have a lite question for a eventual plugin.
A little background to why I am writing.
I have a cnc machine, to program it, I use autocad and the machine's own software. The cnc software is built up so that in autocad you name each layer to different names to get a specific function or iso code that the cnc machine can read and operate, (when I have auto imported the cad drawing as a dxf file ofcourse)
The thing is that these names of the layers I have to use will be very long and curly and difficult to read if there are any errors. As an example of a layer to mill a hole with a pin mill - 6mm on the top, diameter 48, depth 15mm, direction left: TCHW0B1D1500PT1DIR0TC1DI600. it is quite hard to read after a while, atleast if you use like 10-20 different functions for one pice.
So my question is if there is any type of layer plugin that can make a layer according to what you click or choose. Simply choosing a new layer, then you can choose which side the processing should be on, then choose what kind of operating(like mill, bore, saw etc), and so on until it has created a layer, like the one above. (after what has been configured in something like a tool list and variable list.)
best regards Markku
