Cad File Cannot Open
jayhar
Advisor Advisor
Message 1 of 9
jayhar
Hi all
I cannot open this cad file. i try "RECOVERALL" command. I am working AutoCAD 2015, I try different Version (2013, 2014 & 2016 LT), two or more days i worked in this file, file saved in same path.
What is the Matter? How this file becomes like this? Please help me friends
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
Replies (8)
Message 2 of 9
Libbya
Wrong forum.  You're in the Dynamic Blocks forum.
Message 3 of 9
pendean
Community Legend
Community Legend
There are many ways to try and fix a file, here is the list, help yourself https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/AutoCA...
Message 4 of 9
jayhar
I did not receive the "Drawing file is not valid" error when opening the DWG file. i will open file sudden hang & close
Then i try this......
 1, Open a blank DWG and run the RECOVER command. Select the problematic file. AutoCAD will attempt to recover the file and open it
2, Open a blank DWG and run the RECOVERALL command. Select the problematic file. AutoCAD will attempt to recover the file and open it
3, Open a blank DWG and run the INSERT command. Select the problematic file and see if it will insert. If it does, then run EXPLODE and select the inserted block. Run AUDIT and PURGE commands, and then use SAVEAS to create a new DWG
4, Look in the same directory where the DWG resides and see if there is a BAK file of the same name. If so, rename the BAK extension to DWG and see if the file can then be opened
5, Look in C:\Windows\Temp for files with an SV$ extension. If any exist with a similar name to the corrupted DWG file, then rename the extension to DWG and see if it can then be opened
6, Try opening the drawing using DWG Trueview. If you can open it there, convert the drawing to an older DWG version and try opening again
7, Go to your backup system and restore the file from a time before it became corrupted
No Use........
Message 5 of 9
pendean
Community Legend
Community Legend
Your file is attached after a few tries of the tips I posted earlier... . It wasn't that hard to do.
Message 6 of 9
jayhar
Message 7 of 9
jayhar
Hi, @pendean
Please find the attachments here the another CAD file cannot open
Jayhar.M.J
Message 8 of 9
pendean
Community Legend
Community Legend
Message 9 of 9
jayhar
Hi @pendean
Please help one more CAD file add
Jayhar.M.J
