CAD Dimension - Text location
The dimension in white is how this naturally comes in. I would like the green one where the text value is on the other side with out exploding the dimension. If I use linear dimension to show it on the right, it put the text above which is what I do not want.
user181
Hover on the grip on the dimension text and a menu will appear. If you select the Move with Leader option you can move the text to the other side
That is what I was looking for, but now look whats happening to the dim line. By the way, this is LT 15 shouldn't make a difference though
user181
Select the dimension and then on the properties palette and try setting the Dim Line Inside to ON
my is on, here is a complete list
scot-65
Investigate one or the other or BOTH of the following dimension variables:
DIMJUST
DIMTAD
Please note these settings will affect horizontal dimensions where
you want to position the vertical ones...
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
Neither dimjust or dimtab had the corrected the extension line issue now
