Announcements
Break Line Symbol not accepting input
goalieump413
goalieump413
First time post...
My question is about AutoCAD 2018, Express Tools, Break Line Symbol. After trying to adjust a couple of the drop down settings, the Break Line Symbol no longer accepts input. I can start the tool, change options (keeping the default 'BRKLINE.DWG' as the block), but once I select the first point, I can no longer select the second point to create the symbol. I can click in Model Space somewhere, but that point never gets locked in. Right clicking the second point also indicates 'invalid point'.
The current block is still the default 'brkline.dwg', and all I've adjusted are the sizes and extensions. I've tried a variety of adjusted parameters, but to no avail.
Any suggestions as to how to return the Break Line to default behavior?
Screenshot below...
imadHabash
i suggest to restart your AutoCAD and try to do it first in a new blank dwg .
Imad Habash
JohnHolding
Hi How are you going?
I am having the same issue I have not been able to find a work around other than to create my own break line symbol as a poly line then using TR (trim) cut the lines that extend beyond the break line.
Not ideal but workable
cadffm
IF you have really the same issue like threadopener(TO), it should be easy.
I think the TO case was only  that the block size or better the setting of DIMSCALE did not harmonize with the specified distance between 1st and 2nd point.
The distance from 1 to 2 was too short to represent the icon with the current settings.
If you test in a new blank file with the default icon, you should get the same error message so try a 10x longer distance, 100x longer distance.
For example: New file based on ACAD.DWT
Distance between p1 and p2 = 1 should work.
Breakline [F1]
http://help.autodesk.com/view/ACD/2018/ENU/?guid=GUID-88667D3B-C98B-4C02-85F4-232DD4950841
Sebastian
sachendra_choudhary
Observer
Observer
Either you reduce the Breakline Symbol size as per your need then try this or you should create breakline of longer length.
cmd:
Breakline ---> size ----> 0.25 (To reduce breakline symbol size)
Hope it works.
Best wishes
Sachendra
meobeo257
Community Visitor
Community Visitor
Thank you
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
