Bold/Fat Text when printing
richard
Observer
richard
Observer
Observer
Ive recently had a new desktop and I didn't transfer my settings over from my old machine and now when I print drawings off all my text and dimensions appear bold/fat I've looked at lightweight on the printing settings however
that doesn't change it?
Could anyone please advise as it has a real impact when I print off my drawings and doesn't look as neat.
I have attached 2 drawings, one with the clear cut text from my previous settings and one with the bold text it now appears.
alex101000
Have you messages about missing fonts ? Check message display.
Is the print run on the same device?
What kind of font is your text? Is it shx (stick lines eg Romans) or ttf (not dependent on lineweight eg Arial)?
  • If it's shx, check which ctb or stb file you are using and whether the text is still using the same lineweight (you might be using a ctb file with the same name but actually different settings inside the file). Try copying the ctb/stb files form your old machine to see if you get better results (NB if you're using plot style files from a network drive it should be the same on each computer - but I would still check the file. In the plot dialog, click the button next to the box where you pick the ctb to open it up.plot styles.JPG
  • If it's a ttf (True type font), check that your text is at elevation zero (Z position in Properties) and that the viewport is also looking at elevation zero (activate the viewport and look at 'Centre Z' under 'View' in the properties palette). Mismatch between the two can result in text looking bold on a plot. If you look closely here you can see it on screen before plotting:
majder2007
I have same problem. I am using arial font. On old computer its printing okey but on new one is fat.
I copy all files all font everything that i thought of, but it is still printing like that.
Can you help me if you solved your problem?
Thank youi
melissakimwood93
Community Visitor
Community Visitor
Hi, Im having the same issue, having just updated my AutoCAD - Did you solve this issue?
majder2007
Hi, i did not yet. Please let me know if you will…
pendean
Community Legend
Community Legend
@majder2007 @melissakimwood93  I can't tell if either one of you had a chance to try the already posted solutions above your posts that works well for 99% of users with this issue, here is the direct link if you need it
https://forums.autodesk.com/t5/autocad-forum/bold-fat-text-when-printing/m-p/8468240#M960963
If by change neither addresses the issues for you, here is how to open a support case with Autodesk if you are on subscription to seek out Autodesk Support's help, they can get into your PC and diagnose the issue better:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-find-my-sup...
HTH
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
