blocks with multiple attributes import and export
So I want to create a simple block ( hatched circle ) with multiple attributes. the block represents an object found in a survey. - x-coordinate - y coordinate - z coordinate - characteristic a - characteristic b - characteristic c I want to be able to import these blocks ( usually about 50-400 objects ) within a drawing based upon X and Y coordinate, but have the Z and characteristics visible within properties. import through .TXT, .CSV or .XLS the objects should also be able to be exported to .TXT, .CSV or .XLS I allready tried to build a block like this and export ( attext) templates files to do so, but without succes. Can someone help me please?
maratovich
Give us an example of your file.
Software development
Automatic creation layouts and viewport. Batch printing drawings from model.
www.kdmsoft.net
Will do so as soon as I get to my desktop@work.
Thought of that already, but thanx
S.Faris
Use DATAEXTRACTION to export properties of the block to an excel file.
Refer to this : Extracting object coordinates to an external text file in AutoCAD
SALMANUL FARIS
So I want to import blocks in a drawing with attributes taken from an excel. and vice versa ( extract block attributes from a drawing to an excel. )
3 of the attributes are geometry values ( X,Y and Z ) these should be incorporated.
the other 2 values are generated from a third party ( survey software ) and represent max nT and AM2.
in the example attached the X,Y and Z values are manual input. these should come from the insertion point off course.
I use an attext template to extract the X,Y and Z values. but I haven't had any luck yet extracting the MAX. nT and AM2 values.
