- Mute
- Permalink
- Report
I am having a hard time understanding the differences between the two. So I made a block and gave it a name. In the .dwg that I am in, if I type ddinsert, the block appears with the name I gave it when I had created it using the block command. It is saved in a drawing on my desktop. So, then, when do I use WBlock? I want to place the drawing in a folder designated for only blocks, but I also want to know if it makes sense to create a WBlock now that I plan on putting it in a folder, with the given name I chose. I guess it is a dumb question because I'm not sure if I should have created the Wblock first, draw it, name it, save it, then block? Or the other way around. That is where I'm stuck. Any help would be appreciated. The block, if it matters, is a dynamic block.
