I was inserting a block from the Blocks Palette when the palette suddenly disappeared (the block never reached the drawing). The pallete won't show even though the corresponding Ribbon button is on. I also tried the commands BLOCKSPALLETE AND BLOCKSPALLETECLOSE. I also closed the program and opened it again, started a new drawing but the mystery persists. Any guidance would be greatly appreciated.
HI,
try to right click on your ribbon ( View tab ) >> show panels , any changes ?
Imad Habash
HI,
Imad Habash
I found it! I noticed the left drawing area margin shifted slightly when I cycled the Blocks Palette Ribbon Button so I decided to start grabbing at the edges and pulling. Low and behold... it came out of hiding. I don't know how to recreate what happened but I'm good for now. Good Day all!
I tried that, but it didn't help. Thanks for your time.
Yea, I did something similar.
I went to the view tab.
inside the Palettes bar, I selected the Blocks Palette Enable/Disable button.
Each time I did it I noticed a very subtle difference on the sidebar as it turned on and off. (Right side in my case - as that's where was last before it "disappeared" )
I hovered over the right side and the expand icon appeared and as I began to stretch, low and behold my Blocks palette was there.
Drove me absolutely crazy because I tried everything I knew how. (short of resetting CAD settings/uninstall-reinstalling the program. )
Thank you very much
You literally saved my day
That issue was driving me crazy
Thank you very much
Hi
Had same issue. Didnt see the display glitch
I guess this happens for thosse having multiple screenand different screen resolutions.
What I did:
I went to the display settings of windows and resized my screen to 100% (guess other settings and resolutions will work too)
And after that I saw the block palette on my other screen bottom part.
Hope it further helps as this is really a tricky issue.
Hi
What I did:
God bless you!! Nothing else was working and I followed your advice and BAM, there it was!!!
You're a lifesaver!!
thankyou, i had exactly the same thing.
extremely annoying. please fix autodesk.
i do not see blocks palette under view-palettes. Can anybody help me to bring back my blocks palette?
@t_yun33XGH wrote:i do not see blocks palette under view-palettes. Can anybody help me to bring back my blocks palette?
If you don't see this here
You can type the command name for it
Then you might be in a year-version that does not have it.
thanks, took me a while but i found a thin sliver and it expanded into the block palette
