Blocks not updated in drawing
joe_kohli
Message 1 of 12
joe_kohli
I inserted a newly built block that I just recently constructed/built (in block editor) in a separate Autocad drawing named "Blocks". I copied and pasted into a drawing that I am working and realized that the block needed a modification quick. I went back into the "Blocks" drawing and modified it. I then copied THAT newly modified block into my current project, but the block is still showing up as the "old, not modified" block. It is not updating and showing the new changes. Why?
Replies (11)
Message 2 of 12
cadffm
you didn't copied a block (blockdefinition), you copied a blockreference!
If you like to update your already present blockdefinition, use Designcenter
https://help.autodesk.com/view/ACD/2024/ENU/?guid=GUID-09581E02-567B-4D12-B72B-6CD8B5EF711D
or Block palette
Navigate to the source file, search for your block in questions, right-click ->
Sebastian
Message 3 of 12
Simon_Mathews
you need to purge out the old definition of the block before you can insert the newer version .
Message 4 of 12
pendean
Community Legend
Community Legend
@joe_kohli wrote:
.....It is not updating and showing the new changes. Why?
Copy/Paste has no replace-an-old-block-with-my-new-block-definition option, wrong tool for the task, it does not and did not prompt you to replace anything I assume, correct?
You want to use tools that let you replace one old with one new that share the same exact name: looks like you have many already shared, give those a try.
Message 5 of 12
joe_kohli
I have tried to select all and "purge all checked items" and it appears that nothing is fixed. The new blocks still do not show the modifications.
Message 6 of 12
cadffm
You didn't purged the block.
Purge is available for unused item only.
Sebastian
Message 7 of 12
pendean
Community Legend
Community Legend
If the blockname is present and being used in the file, that will not get rid of it: start RENAME command, give the block in the destination file a prefix or suffix so it is indeed different, then insert your newly minted block from the source file into that same destination file.
Message 8 of 12
joe_kohli
Where does the default block destination file go on your pc? I cannot find where it is being placed after I save the new block.
Message 9 of 12
cadffm
You can save a FILE, not a block..
What I understood:
You have one file "blocks.dwg", where you created a block, say "Block1" (and saved this file).
You copied one blockreference of block1 and pasted into another drawingX.
By this step, you also copied the block(definition) of block1, because in drawingX was no block with name block1 defined.
Later, you edited block1 in blocks.dwg
Now, you want to update/redefine this block1 in drawing1.
Is it wrong?
Or did you used bedit in blocks.dwg and used <current drawing>?
If so, it isn't a block, but you can Insert this file 'as block'.
The solution is also Designcenter, Blocks palette (or classicinsert)
but in this case you have to do the right click on this file.
Or in classicinsert, [browse] for it.
https://help.autodesk.com/view/ACDLT/2024/ENU/?caas=caas/sfdcarticles/sfdcarticles/How-to-redefine-b...
Sebastian
Message 10 of 12
joe_kohli
Is it wrong?
This is correct!! How do I do this? I have tried everything and yet block1 still does not show the new changes made when I reopen it in drawing1.
Message 11 of 12
cadffm
as I and others wrote.
Read all replies again, try to follow and if you can't - share it by Screencasts or a row of Screenshots
We don't have you both drawings (you didn't shared) and we can't see your monitors
or Block palette
Sebastian
Message 12 of 12
joe_kohli
This last reply answered my question. I'm sorry for not being more clear on what I wanted. I appreciate your patience and understanding!!
