Blocks - Lines move unexpectedly, Attributes stay in correct location
Message 1 of 8
I am having a problem with my blocks containing attributes. When I place them in a drawing and then close/re-open the drawing the block linework has shot off into space but the attributes stay in the correct location. this seems to only happen to the blocks I have mirrored. I am using AutoCAD 2013 and I know this problem doesn't happen in newer AutoCAD versions. Is there a work around for this that doesn't involve updating my version of CAD?
Replies (7)
Message 2 of 8
john.vellek
Hi @Anonymous,
Is it possible to attach some of your blocks so I can try to duplicate in order to give you some suggestions?
John Vellek
Message 3 of 8
See attached .dwg
See the block below "misc.". looks like its just text but the rest of the block is way off to the right of model space.
Message 4 of 8
john.vellek
Hi @Anonymous,
Try this version of the Section block and let me know if it behaves differently.
John Vellek
Message 5 of 8
imadHabash
HI,
BATTMAN will help you.you need to Synchronize the attribute. type battman in command line then select the block then press Sync icon. see attached image.
Imad Habash
Message 6 of 8
That works the same as attsync. The problem is that when it syncs the block it moves the text over to the line work, I need the line work moved over to the text (the text always stays in the right spot). It happens randomly, so I may have 50 blocks in my drawing and when I go to open it the next day its a mess. Is annoying having to move all of the blocks back into their correct spot.
Message 7 of 8
@john.vellek That block seems to be working as of right now. What did you change? I also noticed that when I have my block at scale 1:25 looks fine but at 1:1000 it separates the line work from text.. maybe I did something wrong when creating it?
Message 8 of 8
john.vellek
HI @Anonymous,
I changed the base point within the block to 0,0.
I do think it might be worth some time to rebuild the block. I hate trying to troubleshoot an existing one and it is likely to build from scratch.
I suggest that you post in the Dynamic Blocks forum for additional suggestions on how to build it a bit cleaner.
John Vellek
