Block to polyline batch conversion
ksakethk
ksakethk
I have a drawing file with multiple blocks. I need to convert these blocks into polylines so these polylines can be recognised in another application.
Changing each block into polyline using explode command is easy but time consuming since I have many blocks. Is there command or small line of code that converts all of the blocks to polylines.
Thanks in advance.
Saketh
ВeekeeCZ
You can try WMFOUT/WMFIN. But you might lose some preciosity.
I would definitely prefer EXPLODE over it.
StanThe
You might try NCOPY. I use this to pull out pieces of blocks, then you can keep your block intact also.
SH
JTBWorld
If it is time consuming to run Explode on each block, then run Explode and then enter All or select multiple blocks.
Jimmy Bergmark
JTB World - Software development and consulting for CAD and license usage reports
https://jtbworld.com
maratovich
Add an example file with your blocks.
Automatic creation layouts and viewport. Batch printing drawings from model.
www.kdmsoft.net
