Block scaling problem
Hi
When I insert a basin, which is 400mm x 500mm from the blocks library, it becomes 125350mm x 163453mm. How do change it to correct size
Tess
Alfred.NESWADBA
look to the units in the source drawing and in the destination drawing, if the settings are different then AutoCAD does the scaling for you.
If the units are set to <Unitless> then see the setting in system variable INSUNITS.
You might also look to >>>this thread<<< working with some commands about different drawing- and system-specific settings of units.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Hi Alfred
Thanks for the reply & your advice worked
Tess
Alfred.NESWADBA
thank you for your feedback, good to know this is question solved for you.
- alfred -
Alfred NESWADBA
