AutoCAD Forum
block file path
2 REPLIES 2
1149 Views, 2 Replies
block file path
Hi am curently doing a job at work that a previous employee has worked on,
they have used a block for on of the drawings and i need to know the file in which it came from
any ideas on how to do this, i cant find anthing that shows its file path.
2 REPLIES 2
imadHabash
Hi and welcome to AutoDesk Forum,
you can follow blocks and many things else by using ADCENTER command (Ctrl+2) see attached .
Imad Habash
Alfred.NESWADBA
A content of a drawing does not have something like a signature about "where it comes from".
So you might search your network folder for a file that contains a block with the same name or you can search for a file that has the same name as your block, but that does not say anything about "this is exactly that block".
A simple example, you might have got drawings from different vendors (persons or companies) and each contains a block "table" ... and they are different.
So just be careful, to find something with the same name does not mean that this is the real source of your block-definition.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
AutoCAD Inside the Factory
