BLOCK CONTROLLED BY MORE THAN ONE LAYER
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am using Autocad 16 and have run into an issue, and am curious if anyone else has run into it.
I have a library of blocks that are used in typical drawings. When brought into a drawing through the Tool Palette, I will place them on one of two layers either called Notes or Dim. When I check them in properties they correctly will show the layer I have them on. What is weird is that another layer called Symbol will turn these blocks on and off even though they are not on that layer? The blocks were made during the process of dragging the original CAD file from Windows Explorer into the Tool Palette. When you drag and drop the item from the tool palette onto model space it is now a block reference.
This symbol layer is not any kind of special layer. None of the other layers will effect these blocks the way symbols does. Any ideas?
