block blocked
block blocked
block blocked
I was creating a block in a file (AutoCAD 2012) and closed the file giving him to save, without giving a block before closing. What happens is that opening the file again appears ONLY the block, that the rest of the information is out there. But I can not close the block in any way, or close block or anything! It is very rare but I hope I have a solution, x what comes to me!
chriscowgill7373
http://images.autodesk.com/adsk/files/block_editor_save_corruption_hotfix_readme1.html
https://knowledge.autodesk.com/support/autocad/downloads/caas/downloads/content/autocad-2012-block-e...
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2026 on Windows 11
imadHabash
>> But I can not close the block in any way <<
i suggest to type BCLOSE in command line and see what happened.
Imad Habash
bclose is not possible!
Unknown command "BC".  Press F1 for help.
I´ve already drawn again. Thanks a lot!
Alfred.NESWADBA
Are you in block-editor when you started that command? Because this command is only available within block-editor!
And just to make sure: try that:
_.BCLOSE<ENTER>
(just BC)
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Nothing Alfred...
Unknown command "BCLOSE".  Press F1 for help.
Thanks for the comment!!!
Alfred.NESWADBA
Well, in case you are really in block-editor and this command is not recognized then try a reset settings to default so you get a clean AutoCAD profile (
>>>details<<<), in worst case a repair installation might be needed.
If you first want to verify more details - before you do a reset - let's start with a screenshot from your block-editor mode.
How does it look on your system. Mine looks like that (and has an icon for closing the blockeditor), how about yours?
Another screenshot from the command-line ... after you have entered _.BCLOSE<ENTER> might also be helpful.
- alfred -
Alfred NESWADBA
