- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have a block, which needs to know the insertion point of another block. This is fairly easy to achieve with fields.
Anyway, I need to do this hundreds of times. Luckily, the reference block (the block, which x,y-coordinates I need) is the same for the "hundreds" of blocks I have, so I thought that once I've done it the first time I might just copy the field to one block and paste it to all the respective blocks (in the properties palette). This didn't work since the value is static...
How do I copy a field when it is a block attribute value? It doesn't seem to be possible to even copy the field within the same block from attribute to attribute...
-F
