Block Attribute Reference String
Jake_CAD
Message 1 of 12
Jake_CAD
My aim is for the ID attribute in the block below (attched) to show the following (as indicated in the Target image below);
  1. All of Loop (L) Field
  2. First 3 characters of Address (A) field
Is there a way to do this?
Block Attribute ref:
Target:
Accepted solutions (3)
Replies (11)
Message 2 of 12
pendean
Community Legend
Community Legend
@Jake_CAD Where would that information come from to feed those strings?
Message 3 of 12
Jake_CAD
Manual input into the Block Attributes
Message 4 of 12
paullimapa
But in your OP that screenshot seems to show the ID value is filled out as a Field (text with gray background). But now you’re saying that you are manually entering the ID value. Which is it?
Paul Li
IT Specialist
@The Office
Message 5 of 12
Jake_CAD
Hi Paullimapa,
The ID is a field pulling string(s) from 2 of the other block attributes (labeled L & A) - attributes L & A are manually entered. I essentially want the ID to be automatically filled out using a combination of manually entered attributes of L & A.
The screenshot showing the Field is a screenshot of the attached block, which almost does what I want it to do. However, I have only managed to get the ID field to pull the values from the other 2 block attributes by opening and closing it in block editor.
Message 6 of 12
paullimapa
Strange because when I insert the Fire Alarm block into a new metric drawing the ID is not rotated vertically but left horizontal and way down below the insertion point in the far lower left hand corner.
I also cannot get the ID to fill out by opening and closing the block editor.
Paul Li
IT Specialist
@The Office
Message 7 of 12
Jake_CAD
Hi Paul, that is very strange!
That aside, it would be useful to ascertain if what I want to achieve is possible - ie. A block attribute using a field that references other (manual input) attributes in the same block. To help convey this intention, I have produced the below diagram;
Message 8 of 12
Simon_Weel
Ahh them Attributes. Remember - an Attribute Definition is part of the Block Definition. The value of the Attribute is tied to the Block Insert.
I.e. while you could use the Attribute value of a Block Insert in a field, you have to manually make the connection between the two for every Block Insert.
Message 9 of 12
Jake_CAD
Hi Simon - thanks for your response. That makes sense and explains why it worked once the block editor was opened.
Any alternative suggestions that may help me achieve my aim would be welcomed!
Message 10 of 12
Washingtonn
You might investigate inserting blocks including manual attribute inputs within a lisp routine which also combines into ID attribute or once blocks have been inserted, run a lisp routine to combine selected block attributes into ID attribute.
Another way could be by placing blocks, ATTOUT to excel, with an excel formula to modify/update attributes and then ATTIN to update existing block in AutoCAD.
Message 11 of 12
Jake_CAD
Hi Washingtonn, do you have any specific lisp routines that I could reference for this type of functionality?
Message 12 of 12
Washingtonn
Here is a method (non-lisp) you can use to update the blocks after the initial manually enter data has been competed. A master file can be created which could import the raw data, modify it and output the results very quickly (with the press of an Excel button).
