Block Attribute elevation
Message 1 of 8
Why is the attribute on other elevation than z=0?
The block is imported from another application.
How can I move the attribue to z=0?
Replies (7)
Message 2 of 8
imadHabash
there are many ways for that ... i suggest to try some of them as mentioned here . >> Click <<
Imad Habash
Message 3 of 8
cwr-pae
It appears someone moved the attribute to a snap point on an object with a non-0 elevation. If you insert the block with the insert command the new instance will have the attribute at its default elevation of 0. You can also draw a line from the insertion point of the attribute to any point nearby, set the z values of the line to 0 and then snap the attrib to that line's start to reset that instance of the block.
Message 4 of 8
cadffm
Nobody here can know this,
but three way in general:
1. Someone tried to move the the block reference by grips and took the attribut grip instead the grip of block reference.
2. The block reference was created at a time where the block definition looked different (with attribut definition Z=42.2483..
3. Someone used a program to flat the drawing, but used a bad tool for this.
It's also possible in AutoCAD
Sebastian
Message 5 of 8
I received this file with hundreds of blocks like this distributed on different locations and it is making me crazy!
I think something happened during the export.
FLATTEN or CHANGE do not work!
Attribute Editor or Properties do not show information about attribute elevation!
Message 6 of 8
cadffm
But the MOVE Trick from the link above does.
Also ATTSYNC in this sample case, but this changes multiple things more.
Sebastian
Message 7 of 8
3wood
I have tried FLATTEN in AutoCAD 2020 and it works well.
You can also try CHZ20 if FLATTEN doesn't work.
Message 8 of 8
vinodkl
Hi @Anonymous
Try syncing the attributes. Type in the command "ATTSYNC" and select block and the elevation of the attribute will become zero🙂
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
