Blank Page when print or plot to pdf (tried everything)
I have found many questions like this but none of the solutions worked for me.
I tried both to plot and to print but the output is always a blank page.
when I try Zoom_extents I can see my drawing perfectly, my layers are set to print plot.
I'll attach the file here, maybe someone can help me.
Thank you in advance!
a_meteni
All line colors in your blocks are overridden to true color 255,255,255. Just edit your blocks and set color to ByLayer and it should print correctly.
Seems like this is the problem, but I could not change the color of the blocks, I changed the layer's color but couldn't change the color of the block itself.
a_meteni
Use the Refedit command.
