Autocad command line disappearing
Message 1 of 12
Hi everyone,
my command line in AutoCAD 2018 when typing shows only in top left corner for few seconds and then fades away. Also it does not have any button or anything I can change settings or even simply move it. Anyone knows how to solve it or knows a command that I can get to command line options and change all of this? TIA
Konrad
Replies (11)
Message 2 of 12
j.palmeL29YX
Maybe Ctrl+9 ?
cadder
Jürgen Palme
Message 3 of 12
unfortunately not. This command only can turn it on and off, but can no change position or any other options.
Konrad
Message 4 of 12
j.palmeL29YX
Can you show us in a screencast (https://screencast.autodesk.com/Main/About) what happens please?
cadder
Jürgen Palme
Message 5 of 12
Please see the attached screenshot - as said the command line appears only like that in the top left corner with no possibility of changing position etc. and it fades away after few seconds.
Konrad
Message 6 of 12
j.palmeL29YX
I've never seen this before.
Next I'd try  "Reset Settings to Default".
cadder
Jürgen Palme
Message 7 of 12
dgorsman
Your workspace is likely storing coordinates that are off-screen.  Use the CUI editor to force the command line palette to be docked, then reload the workspace.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
Message 8 of 12
scot-65
Perhaps also look into LOCKUI?
(= 0)
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
Message 9 of 12
jayhar
Enter Comment "GRAPHICSCONFIG" and off Hardware Acceleration.  Find the attachments
try it....
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
Message 10 of 12
pendean
Community Legend
Community Legend
Dock your commandline using CUI
1. Run the CUI command to open the Customize User Interface window.
2. On the left side, select your current workspace.
3. On the right side, expand Palettes and select "Command Line".
4. As shown in the screenshot below, change the Orientation setting to "Bottom". Hit [Apply] and [OK] to leave the CUI.
Message 11 of 12
Hi everyone,
thanks for our help. Happened that when I restarted AutoCAD the command line was back at the correct place working normally. Did not have to use any of the solutions you suggested so can not mark which one of them would work unfortunately. Thanks again anyway.
Konrad
Message 12 of 12
This worked!
