blank mtext
blank mtext
Karol_Piroska
Advisor Advisor
blank mtext
Karol_Piroska
has anyone had an issue with mtext going blank with just outlines of the text fields? I can still select it and it shows the value in the properties panel, but the text is not visible.
See attached isolated sample.
user181
Set QTEXTMODE to 0. You may need to do a regen after.
imadHabash
Click on below image to see how by QTEXTMODE (System Variable) = 0 and Regen command you can solve your issue .
Imad Habash
Karol_Piroska
@user181 @imadHabash thanks a lot guys!
