Hello to everyone,
I would like to know why does the pdf that I attached to my autocad file has black on his background... I am uploading a picture of what I have in AutoCAD, and also what I have in PDF. I would like to have the background colored in white.
Solved by imadHabash. Go to Solution.
any changes if you try PDFATTACH command ? if not would you please attache here your original pdf file for testing ?
Imad Habash
Check CONTRAST value for PDF underlay in properties dialog. Set it to 100.
Miljenko Hatlak
use PDFIMPORT command and select Raster Images option as shown in below image . click on below image
Imad Habash
