binding xref files
binding xref files
jwright1962
binding xref files
jwright1962
Wondering if there was a lisp available that binds only loaded xref's,  detaches unloaded xrefs and then moves all the entities on resulting layers with names containing "* 0$0 *" to a layer called "background".
actually, just binding only the loaded xref's and detaching the unloaded xref's would be wonderful.  I think I can manage changing the entities to a "background" layer.
thanks
scot-65
Be careful with BINDTYPE in your first sentence.
You may have more success posting in the Customization section.
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
jwright1962
I click "FORUMS" above and don't see a "Customization section"  would you mind "pointing the way" ?
ukdxb012
Try this link... http://forums.autodesk.com/t5/autocad-customization/ct-p/AutoCADTopic1
Duncan Brannan
UK/EMEIA CAD Operations Manager
Twitter | LinkedIn
you can try with free tool BtahcInEditor or BatchInDatabase to do the binding operation, the bind command removes unloaded xrefs, including the child unloaded xrefs and binds the loadeded xref.
you can choose bind method either "Bind/Insert"
I have added few commands to the batch in the below image.
1. Binds the loaded xrefs and removes unloaded xrefs
2. let you know the bind operation is succesfull or not, if bind is sucesfull then it will report "No Xref Found" otherwise list all the xrefs and its status
3. Purge the drawing
BatchInDatabase process drawings without opening them and BatchInEditor opens drawing and process it
