Bind the xref error
Bind the xref error
Bind the xref error
I'm trying binding a xref, but I get the following error
Means, Some entities in one or some specified xrefs failed to bind.
The xref drawing is in the attachments.
I've tried audit and pu.
imadHabash
open those attached xref and check that all the xrefs inside it are found .
it seems that it's a proxy elements issue !! i get this :
Error: At least one of the specified xrefs failed to bind due to a problem with a proxy object.
i suggest to clean your xref CAD file from those proxies . >> Click <<
Note : i wonder how a such a drawing have many entities ( like yours ) with 1.709 KB file size !!!!
Imad Habash
cadffm
If you want to bind the Xref by INSERT method,
better you use INSERT <file selection>
If you want to bind the XRef by BIND method,
For me this works:
(perhaps some steps are not needed, id didn't try to find the shortest way)
Use QSELECT to select all ACAD_PROXY_OBJECS in modelspace
delete all ACAD_PROXY_OBJECS
<This works for all except two of them>
Use -PURGE REG *
Use -PURGE ALL *
Use -EXPORTTOAUTOCAD
open the new created file
select all objects in modelspace except the kepp 2 ACAD_PROXY_OBJECTs
Use WBLOCK to export all selected objects to a new file
Use this new file as XREF and you should able to bind the Xref.
Do you know about this program:
TCH_KERNAL
缺乏解释器天正图形看不见, 请下载天正插件
网址: www.tangent.com.cn
From this software are the objects in you file.
Sebastian
Thanks a lot, it works!
