BIND IMAGE (JPEG, BMP) TO A FILE (For Title block Logo)
RockyBrown4134
Message 1 of 24
RockyBrown4134
Back some verions ago, there used to be a command in the xref dialog called "BIND", that let you bind an image to a block or file. In 2015, I can't seem to find that option. Does it still exist? Is there another way to BIND an image? Is ther a better way to accomplish my task?
I have to send the image file EVERYTIME I have to send a CAD file out or if someone does not have access to the drive where the logo is stored.
Any suggestions?
Thanks.
If this response answers your question, Please mark this response as "Accept as Solution"
Rocky Brown
AutoCAD 2020 / Inventor 2020 / Plant 3D
Accepted solutions (4)
Replies (23)
Message 21 of 24
Pointdump
Joe,
"...will it cause issues with someone else opening?"
Yes, that's why it's a good idea to use Publish >> eTransmit to make sure everything goes along for the ride.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
Message 22 of 24
callenVCBY3
I exported CAD from Revit. The images that were linked to the Revit file were saved out as external references that were xref in the CAD files. All good, but how do I bind these images to the CAD file instead of just having them referenced? Based on the answers here, I would have to replace each image by copy/paste and then resave. That's cool for one image or one CAD file, but I have multiple files with multiple images. I have to open each of these and run that process!!?
Message 23 of 24
pendean
Community Legend
Community Legend
@callenVCBY3 AutoCAD does not automagically bind referenced raster images with any built-in tools. Sorry.
It is what it is.
You could try using some found LISP customizations on the web to speed up the process, like these https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/insert-multiple-images/td-p/4407911
Help yourself.
Message 24 of 24
thaianefiori
Community Visitor
Community Visitor
Sistema esquelético fetal
