BIG SIZE_FILE
BIG SIZE_FILE
nadel-b
Message 1 of 9
BIG SIZE_FILE
nadel-b
I have a file with a square drawing. the size is 3.7 MB
I tried "purge", "dwg-purge".
Somebody can exlain me whats wrong! All the layers are on and thaw. no xref, no layout.....
ZOOM EX.. a don't see any block.
I send the file.
Bens
Replies (8)
Message 2 of 9
swieciakpawel
I have noticed You have there multiple block references that might not be edited/removed for some reason (maybe because they origin from other AutoCAD product).
If you want to get rid of those, a solution would be to either:
- EXPORTTOAUTOCAD command
- WBLOCK command
Kind Regards,
Pawel
Message 3 of 9
TheCADnoob
I dont have a distro installed at the moment but have you tried dgn purge?
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/AutoCA...
CADnoob
Message 4 of 9
john.vellek
Hi @nadel-b,
I ran through all the usual clean up items such as:
  • Audit
  • Purge
  • -Purge>All
  • -Purge>Regapps
But, as @swieciakpawel points out, there are some AEC proxy objects in the file. His recommendation of -EXPORTtoAutoCAD got the file done to 99k.
John Vellek
Message 5 of 9
nadel-b
I used the command -EXPORTtoAutoCAD  and was OK
Thanks a lot
Message 6 of 9
kamil_konecny
I have one drawing with enormeous size (28MB) even there is only about 1500 entities. I tried the steps above, but the size is almost the same.
Can be other solution for it?
               Thanks a lot Kamil
Message 7 of 9
cadffm
I looked at it yesterday and also saw the problem
with a line of code I can also delete the data with one row of code,
but I knew no way "from a user point of view" to solve the problem.
Today I did a test and it works with native commands and the GUI,
how the user usually works.
However: I have not found a way how the user can find out about the problem at all,
that was only possible in other ways.
So I present the solution, but you cannot check in the program beforehand whether this problem exists at all.
Problem: Data from sheet sets / Sheet list tables   and other data / perhaps from XRef-binding in the past.
Solution: Create a new table set table of contents, this causes an update of AutoCAD which deletes the obsolete data.
Then you can delete the table of contents.
Add one  layout to a sheet set and insert a sheet list table to your Layout.
(You are familiar with sheet sets and Sheet list tables? -> SheetListTable[F1])
That's all, you can delete the new sheet list now.
Sebastian
Message 8 of 9
kamil_konecny
thanks for the answer. I understand the reason of the big size now but I undestand that remowing the unused data from the drawing is not possible by normal AutoCAD commands.
Can you send me the code you using to delete it? We have NET/LISP application and the clearing of the data can be part of it.
       Thanks a lot Kamil
Message 9 of 9
cadffm
Hi
"Can you send me the code you using to delete it?"
It's nothing i saved
If i would save such single lines, the time for searching is much longer then searching the problem and re-writing it again.
And: I am in Holliday, without AutoCAD.
Sorry.
Sebastian
