05:44 AM
When I use Revision Cloud - Rectangle feature in autocad 2016, I sometime get the inverted arc and I can not find a setting that change the arc direction with out using reverse polyline then applying the revision cloud again. Is there a default setting that I can change to draw the revision cloud arc direction correctly? Any help is appreciated. Thanks
