Hi John,
I really appreciate your offer to help. Thank you! I am actually working through this and slowly figuring this out. I don't mind and enjoy figuring it out anyways since I learn better that way and will remember it longer to teach other coworkers to do this also.
I have attached 2 drawings (AutoCAD LT 2013 version) here for Part 1 and Part 2. I was able to include fields and automatically populate the titleblock information so that is solid. I am sorry that this thread has changed direction a few times as I am working through all of this. It is all related though I feel so hopefully other users can benefit from it.
PART 1:
My new issue is that I need objects in model space to appear in the same location in a layout so that I can repeat this process from drawing to drawing. Typically I understand most people don't find this necessary, but I feel as though in my case it is important as I am particular about details and visuals. I haven't figured out how to tell the viewport (with mview command) to start at 0,0 (lower left corner of model space) and end at a certain point. I don't see where it specifies what to display inside the viewport or how it relates to the model display. I have played around with it and looked at the properties, but still can't figure out how it knows what to display from the model tab as it only asks me to specify the viewport starting point and end point inside layout space. The reason I need to know this is to ensure that the object is displayed in the same location from drawing to drawing (For example, if I am trying to display the same model object). I would also like to figure out how to move the object around on my layout drawing if need be.
I create Electrical drawing schematics as I may have mentioned before. I don't need to worry about scaling most of the time or any fancy layer features although I will explore them in the future as I am sure this could prove useful. My intention is to have a standard and keep the drawings and objects in the same location from drawing to drawing which is why I am simply copying/pasting them in layouts right now to have them appear in the same location in every drawing. For electrical lines and schematics there is nothing wrong with copying and pasting them into a layout (that I know of). This being said, the drawing I attached shows an electrical box (operator box or junction box) that I need scaled (1:2) to appear properly inside the titleblock (in layout space). It would be great if you could show me how to set up a viewport so that the viewport uses 0,0 as its origin and have 0,0 be the lower left corner of the viewport so I could copy/paste the box from drawing to drawing using 0,0 in model space as a base point having it appear in the same location in each drawing.
Part 2:
This may pose another issue if I say, want to include my drawing schematic also in model space along with the operator box that needs to be scaled. I have included another drawing with basic lines and objects/schematic symbols to hopefully have you show me how to set up each viewport so that I can not scale the lines and schematics, yet scale the operator box. Would I still just keep the electrical lines inside layout space while the operator box resides inside model space? Or if both were in model space this include 2 viewports I presume. I imagine both can be scaled differently. But then implementing two viewports how would I chose an origin for the viewports to keep them similar from drawing to drawing? Once I figure out how to set up the origin of a viewport or figure out how it chooses to display objects from the model space then I am sure I can figure out how to work out Part 2.
Side note / Extra questions:
Does scaling 1:2 mean that the object inside the drawing is half of its actual/original size ? So you would have to multiply the dimensions by 2 to get its actual size?
What does annotation scaling include and exclude?
