Best Laptops for Autocad 2026
dontanianemp4
Message 1 of 12
dontanianemp4
Hi, I'm a community college student that is taking a computer aided drafting class for my mechanical engineering degree, and I need a laptop powerful enough to run Autocad 2026 so I can use the program outside of campus, since my Dell Latitude 3120 isn't cutting it. If there is anything you'd recommend that has Windows as its operating system and is under $800 please let me know.
Replies (11)
Message 2 of 12
imadHabash
Hi and Welcome to AutoCAD Forum,
I suggest to read and follow this official LINK for system requirements for AutoCAD 2026 including Specialized Toolsets.
Imad Habash
Message 3 of 12
BhaskarMurari
Message 4 of 12
lauri_barnhart
Hello, @dontanianemp4,
Just checking in—did the responses shared by @imadHabash or @BhaskarMurari help clarify your question?
If so, please consider clicking the "Accept Solution" button on the post(s) that solved your problem. Doing so helps others in the community easily find useful answers.
If your question still needs more attention, feel free to reply here with an update. This way, other members can jump in with further suggestions or guidance to help you move forward.
All the best,
Lauri | Community Manager
Message 5 of 12
AllenJessup
We always use Dell Precision. But that's out of your price range. Check out the Dell Pro 16 Plus. The Pro line is supposed to be good. Better than the Latitude anyway.
Allen Jessup
CAD Manager - Designer
Message 6 of 12
dontanianemp4
Is this the laptop that you, personally, use?
Message 7 of 12
john.p.addy
I'm using the Dell Precision 7680 I9-1395 processor w/ 64GB ram, 1TB, and 12 GB VIDEO CARD.  Does everything I need and more.
Thank you,
John Addy
Electrical Engineering Tech.
Department of Defense
Message 8 of 12
AllenJessup
No.  I use a Dell Precision Mobile Workstation. But as I mentioned. Way outside your $800 budget. You could check their website to see what they have for refurbished laptops.
Allen Jessup
Message 9 of 12
AllenJessup
@john.p.addy A little outside the OPs budget. But if they could stretch a little bit. That would be a good choice.
Allen Jessup
Message 10 of 12
dontanianemp4
Turns out that my budget was a little bigger, but the specs of you PC was a great guide, I think I've settled on a Dell 16 Plus Laptop-with the base specs-since it meets the basic requires for AutoCad2026. Thanks.
Message 11 of 12
james9522david
Community Visitor
Community Visitor
Hello! As AutoCAD 2026 requires quite a bit of power, your Dell Latitude 3120 lacks the necessary muscle for seamless operation. For a substantial upgrade costing less than $800.
Consider these Components:
. Processor: Intel Core i5 (12th generation or newer) or AMD Ryzen 5 (5000 series or newer)
. Memory: 16GB (crucial for fluid CAD tasks)
. Graphics Card: Dedicated NVIDIA graphics (RTX 2050 or RTX 3050)
. Hard Drive: 512GB Solid State Drive
Recommended Choices:
.  Acer Nitro V / Nitro 5
. Lenovo LOQ 15
. HP Victus 15
. Dell G15 (look for sale items)
These gaming-oriented laptops offer the most bang for your buck when it comes to CAD work within this price range
. A Little Tip:
You might want to first look for discounts on the Lenovo LOQ 15 or Acer Nitro V, as they frequently provide the best combination of cost and capability under $800. If you can find one equipped with 16GB RAM and an RTX 3050, that would be the ideal configuration for AutoCAD.
Best of luck with your CAD coursework! This setup will undoubtedly make your projects flow much more effortlessly.
Message 12 of 12
alinabutt390
Community Visitor
Community Visitor
Hey, I’m also a student and I had the same issue with my old laptop struggling during coursework. I recently bought one from for my studies and it’s been working well so far. For AutoCAD 2026, I’d recommend something with at least an i7 or Ryzen 7, 16GB RAM, and SSD storage. That setup should handle your CAD work pretty smoothly within your budget.
