Best Autodesk software to use for 3D model and dimension plan
jct22SSRKL
jct22SSRKL
Community Visitor
Community Visitor
Hi, I'm a new user and i have a task to create a dimension plan for a Stone Cairn structure as seen below:
Now, don't come for me but in the past I have used Solid-works CAD but since hearing good things about Autodesk, I thought I should give it a go.
My question is which Autodesk software should I use if I want to create this cairn structure and then use that model to create a dimension plan with the relevant cross-sectionals, etc.
Below is just an example of a plan I put together in Solid-works so people get an idea of the result I'm looking for:
Look forward to getting some good advice from fellow Autodesk users!
Valentin_CAD
@jct22SSRKL ,
Autodesk has a broad portfolio of 3D design software programs - check them out.
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
