Bentley Projectwise Integration with vault
10:10 PM
- Mute
- Permalink
- Report
Has anyone seen instances where the Bentley Projectwise Autocad integration will not work after Vault has been installed?
I have a situation where if Autocad is installed and then the Bentley Projecwtwise integration module is installed everything works fine.
However once Vault is then installed Autocad either crashes on start up or it will launch successfully but without the Projectwise Addin. This happens with both 2018 and 2020.
This is the error occurs once Vault is installed:
Once Vault is removed everything works as it should but I need both Vault and Projectwise to integrate with Autocad.
Any help is much appreciated.
