Batch plot to pdf mutliple drawings with multiple layouts but want each drawing as its own pdf
RubenS1104
8,460 次查看
22 条回复
1 条消息(共 23 条)
RubenS1104
So I have multiple drawings (over 100) that I would like to make into pdf's.  I usually just use CTRL+P for single layouts and then use PUBLISH for a dwg with multiple layouts.  Also use PUBLISH when I have multiple dwgs and want to make them into one pdf or I want to make multiple single sheet pdf's from all my drawings with only one layout.  What I haven't seen is a way to use PUBLISH to make pdf's of multiple drawings of multiple drawings with more than one layout.  I have to open up each drawing individually, PUBLISH, then close and open up then next drawing.  Is there a way to PUBLISH multiple drawings but have each one be its own multipage PDF?  Almost all these drawings are 2-3 pages and I'd like to figure out a way to PUBLISH all of them as their own 2-3 page PDF without having to do them individually.
Thank you.
0 个赞
已接受的解答 (2)
8,461 次查看
22 条回复
回复 (22)
2 条消息(共 23 条)
JTBWorld
已接受的解答
Give our JTB Batch Publish a try as it has more flexibility when it comes to publish to single and multi-page PDF files.
Jimmy Bergmark
JTB World - Software development and consulting for CAD and license usage reports
https://jtbworld.com
0 个赞
3 条消息(共 23 条)
maratovich
No problem, use this - Revers
Automatic creation layouts and viewport. Batch printing drawings from model.
www.kdmsoft.net
0 个赞
4 条消息(共 23 条)
RubenS1104
Thanks, I'm just not prepared to pay for anything without knowing that it works first
0 个赞
5 条消息(共 23 条)
cadffm
Then there is one question only,
why do you say
"just not prepared to pay for anything without knowing that it works first"
instead of test revers?
7 days should be enough to know if it works or not.
Sebastian
0 个赞
6 条消息(共 23 条)
RobDraw
Why not use publish and set it to plot one sheet per layout?
Rob
0 个赞
7 条消息(共 23 条)
RubenS1104
I tried testing it and don't see how to do what I need.  If there is a way to do it and someone know how to do it with revers I would love to know as this is something I've been needing to do for a while.
I have multiple projects that I need to do this for on a fairly regular basis.  For the one I'm working on right now there are about 60 drawings.  Every so often I need to update something in the title block and need to reprint all the drawings.  What I would like to do is publish all of them to pdf.  My issue is that these drawings all have 2-3 and some even have 4 layouts.  I would like to batch print them all but only have one pdf per drawing.  So if my first drawing has 3 layout tabs I want that pdf to only have 3 pages, 2nd is 4 layouts so I only need that one to have the 4 pages.  With PUBLISH I can either print all my drawings as one pdf or each layout tab as a single pdf.
I haven't seen how to do this with Revers.  If it is possible with Revers I would love to see how I need to set it up in order to do this.
Thanks for your help.
0 个赞
8 条消息(共 23 条)
RubenS1104
Publish only lets me either print one pdf that contains all the layouts in all the drawings or single sheet pdf's. If I have 60 drawings I want 60 pdf's, each pdf containing the number of layouts in that drawing.
0 个赞
9 条消息(共 23 条)
Vuxvix
As far as I know, Autocad doesn't have many extended features for printing. I also had the same problem as yours.
The way I do it is to use sheet set Manager to import all the layouts of the drawings I need and publish them in a single pdf file.
Then use a PDF editor (Acrobat Reader) to split them into sections (And be careful not to split the wrong number of pages).
Even with Sheet set manager: Page numbering is also a problem. As of now you can only enter it manually.
0 个赞
10 条消息(共 23 条)
maratovich
Please attach an example of your .dwg file
There is a video tutorial on the site, have you tried it?
www.kdmsoft.net
0 个赞
11 条消息(共 23 条)
JTBWorld
Did you try our JTB Batch Publish app? Try it for free to see if it works for you.
Jimmy Bergmark
0 个赞
12 条消息(共 23 条)
RubenS1104
I usually end up opening them individually and creating the pdf's. By making one pdf and splitting I have to make sure I get the correct pages and then have to rename the pages I save from it. I just feel like its an extra step. I just open the drawing, publish and since I have the page setups already in the drawings it goes pretty quick for each drawing but it still adds up when I'm doing it for multiple drawings.
0 个赞
13 条消息(共 23 条)
RubenS1104
I did check out the video but didn't see how to do what I am trying.  I attached two examples.  Each drawing has a COVER page.  One has two layouts including the cover page and the other drawing has 3 layouts including the cover page.  I had to remove info from the cover page and title block before attaching them here so thats why they look blank
0 个赞
14 条消息(共 23 条)
RubenS1104
I'm going to give JTB Batch Publish a try and see if it works.
0 个赞
15 条消息(共 23 条)
pendean
Community Legend
Community Legend
Use SSM at all? One saved SSM file for each project that is. It will speed up your need to do it than your current harder way by a bit, but your desire does not exist in the program.
You will need to find and purchase a 3rd party add-on tool to do what you want: whip out a credit card after trialing to see if it meets your needs https://jtbworld.com/jtb-sheet-set-publish
HTH
0 个赞
16 条消息(共 23 条)
RubenS1104
I have used it in the past. I end up using PUBLISH now. I have a few dsd files created for each project when I need to print the whole set in one pdf or to just print the wiring drawings, or just the equipment drawings, etc... The 3rd party app is what I'm trying to find now to help with this. I'm gonna be giving JTB a try today to see if it will do what I need.
Thank you.
0 个赞
17 条消息(共 23 条)
kirillovdm
Watch it
<iframe width="640" height="710" src="https://screencast.autodesk.com/Embed/Timeline/c031fe07-26d9-4ccf-b094-34f83f52646a" frameborder="0" allowfullscreen webkitallowfullscreen></iframe>
0 个赞
18 条消息(共 23 条)
maratovich
已接受的解答
Watch the video in the previous post.
www.kdmsoft.net
0 个赞
19 条消息(共 23 条)
Vuxvix
Hi!
I think the layouts you need to publish are not just done once, right? do you still have to reprint them every time there are edits!?
At least with sheetset you have to do it once. It also preserves the page setup for each layout. Or you can overwrite as needed without changing the settings for each layout. If there is no regulation on naming sheet for each project. I will leave the default: NameDWG-Namelayout.
Hope you find the right solution. i am also trying JTB batch Publish to improve my WIP.
0 个赞
20 条消息(共 23 条)
RubenS1104
Thanks, this worked great.
0 个赞
