I'm trying to batch plot several drawings to PDF. however, I'm encountering a couple of issues
Issue 1: when the drawing gets converted to PDF it doesn't perfectly fit within the window. I read in another article that you can fix that by changing the pdf options. however, pdf options are not accessible in the batch plot window, that feature is only available in the print window, which would not help me since I'm converting multiple drawings to PDf, not just one.
Issue 2: the lines are thick on the pdf. When I try to adjust the line weight it only fixes it for the drawing that I have initially opened in Autocad, not for the ones I added in the batch plot window.
Appreciate the support!
Cheers,
