BATCH PLOT ERROR
BATCH PLOT ERROR
BATCH PLOT ERROR
when i try and plot this error message comes up. Can anyone please help.Error Message.JPG
M_Hensley
You have a job plotting in the background. Turn off background plotting. Go to Options, Plot and Publish and uncheck Enable background plot for both plotting and publishing.
Thank you,
It has worked
ajayyK48L5
Observer
Observer
Thanks for this solution
srinu_v3ds
Community Visitor
Community Visitor
It is working
Thank you
manieshkumar.suresh
Hi there,
Good day!
This warning may occur if background plotting is enabled.
Disable Background Plotting
When background plotting is enabled, no more than one drawing can be sent to be plotted at the same time. To disable background plotting, do one of the following:
  • Set the BACKGROUNDPLOT system variable to 0.
Kindly refer this article for future reference - "A plot or publish job is already being processed in the background" in AutoCAD products
