Batch macro actm format
Hi i have recorded a macro on the internal macro on CAD and im getting a actm file i wonder if its any possibility to have a script or a separate program to run the macro on several other files?
cadffm
In AutoCAD are'nt a Batch-function for that, but many possible solutions.
Search and read about AUTOCAD BATCH and you will get multiple solutions, for all you have to learn how it works.
About Actionmacros:
Create your actm and use a name that is not used yet, because Acad get you active-macro name and create a new command for it,
so you can start the a.macro like a normal command: MyPurge1
<Example-Search4u>
<AutoDESK APP Store>
Sebastian
