Batch converting DWG to DXF
deoriodp
Message 1 of 14
deoriodp
All, anything built-in to batch convert multiple DWG files to DXF.... quick and simple?
Replies (13)
Message 2 of 14
pendean
Community Legend
Community Legend
Message 3 of 14
Alfred.NESWADBA
alternative could be to use ScriptPro >>>click<<<
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 4 of 14
JTBWorld
Not built-in but or batch processing app SmartPurger can do this: https://jtbworld.com/smartpurger
Jimmy Bergmark
JTB World - Software development and consulting for CAD and license usage reports
Message 5 of 14
ryan_scott_KA
I just downloaded this but I cant see where it converts dwg to dxf.
Message 6 of 14
JTBWorld
Documentation tips:
How to convert multiple DWG files to DXF:
Our JTB SmartBatch app could be used together with a simple script like the below (save to a file with .scr extension) that save each drawing to DXF with JTB SmartBatch.
Script code starts below:
FILEDIA
0
_SAVEAS
DXF
_V
2013
FILEDIA 1 QUIT
Script code ends with the QUIT above and the last row can be empty or having a semicolon.
Depending on how you want the DXF files to be created you might want to modify it slightly.
Drawings saved in DXF format have these additional prompts.
  • Decimal places of accuracy. Specifies from 0 to 16 decimal places.
  • Binary. Creates a binary DXF file. Binary DXF is generally faster and more compact than ASCII DXF files.
  • Select objects. Prompts you to select specific objects to be saved in DXF format.
  • Preview. Specifies whether you want to save a thumbnail image of the saved file.
  • Version. Specifies which product version to use for the saved DXF file.
Jimmy Bergmark
Message 7 of 14
ryan_scott_KA
Thank for the reply, I just made and used this in AutoScript seemed to work ok.
FILEDIA 0
DXFOUT
FILEDIA 1
Message 8 of 14
morten4MDUW
How to save dxf with this ?
Message 9 of 14
cadffm
the first line of his answer is a LINK, follow this link
install and set up the product and follow the documentation
(you have to create a script with the content above, copy all lines, paste it in notepad, save it as yourfilename.SCR )
Sebastian
Message 10 of 14
morten4MDUW
if i have like 20 dwg files  in one folder and want to convert all 20 to dxf how so?
Message 11 of 14
pendean
Community Legend
Community Legend
You need a script file, and a script processor to run it through all of those file: this one works well in our office
https://www.cadig.com/products/autocad-script-pro.php
Or try others
https://apps.autodesk.com/ACD/en/List/Search?isAppSearch=True&searchboxstore=ACD&facet=&collection=&...
Message 12 of 14
paullimapa
Try attached DwgACCDwg2Dxf.lsp which offers you the option to select the folder with the dwgs to save as dxfs without the need to open them in AutoCAD' GUI
Paul Li
IT Specialist
@The Office
Message 13 of 14
morten4MDUW
thank you! thats it !
Message 14 of 14
paullimapa
You are welcome…cheers!!!
Paul Li
IT Specialist
@The Office
