- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello to all !
I would like to ask if there is any workaround to bring back the BASEVIEW option to AutoCAD 2019 32 bit, so it is possible to create various projected views in paper space from a 3d solid in model space.
An workaround like copy some dll from a 64 bit AutoCAD installation into AutoCAD 2019 32 bit, or other " trick " that enables the command on AutoCAD 2019 32 bit.
If a usable command like BASEVIEW is completely out of question in a AutoCAD 2019 32 bit installation, is there any way to achieve the same results, using more steps ?
I tried to create various viewports on paper space and then change the view orientation for each one, but individual viewport orientation change was not allowed.
Does anyone have some ideas on how could it be done ?
I will appreciate very much any idea or information !
Best regards
PR
