Hello!
In past projects we have used base views to produce plans and elevations and have had no issues with the section tool.
For a recent project, I am trying to use base views to produce the section cuts, but for some reason the sections are not honoring the boundary. As you can see, the arrows are cutting off a corner of the model, but the elevation shown is more of a projection from that angle.
I have tested multiple models created from the same DWT and received the same result.
I have also tried running VIEWBASE on the drawings that have worked in the past and those still works, so it leads to me to believe there is something off in this DWT?
Anyone have any ideas?
@jshendricks wrote:...so it leads to me to believe there is something off in this DWT?
We will need to access that DWT file, can you share it here? If not, reach out to colleagues or the DWT file creator for guidance.
One of the the ideas would be not to be too far from the origin (0,0)....
A second one, coming to me, would be to WBLOCK all and try in this new file...we never know.
An article and another one about fixing
