Balloons? How do I add a balloon leader line in AutoCAD 2019?
How do I add a balloon leader line in AutoCAD 2019? So far this is impossible as far as I can tell. Please help.
Alfred.NESWADBA
not sure to understand you, but wouldn't creating a multileader style do what you are looking for?
If I'm misunderstanding your question then please show us one sample manually drawn so we can see what you would like to get.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
1.PNGGo to the annotation tab
2.PNGModify
Go to content
3.PNGAnd select block
Have a look at the prompts after you place you new leader
rkmcswain
See below.
R.K. McSwain     | CADpanacea | on twitter
hencoop
Hmmmm.... If you mean how do you do this:
Specify the "Dot blank" arrowhead in its properties or its style for the one on the left.
Create a block suitable for your arrowhead replacement and specify that as your arrowhead in its properties or its style (as was done for the mleader on the right).
AutoCAD User since 1989. Civil Engineering Professional since 1983
Product Version: 13.6.1963.0 Civil 3D 2024.4.1 Update Built on: U.202.0.0 AutoCAD 2024.1.6
                        27.0.37.14 Autodesk AutoCAD Map 3D 2024.0.1
                        8.6.52.0 AutoCAD Architecture 2024
