Balloon referencing and parts lists
Autocadders around the world
When I started here 1 1/2 years ago, there was no indication of balloon referencing
or parts list on the drawing at all. The parts list was a separate excel spread sheet,
and there was no link between that spreadsheet and the autocad drawing at all.
Thanks to feedback from this discussion group, I am now using, multi-leaders with circle blocks,
with attribute tag numbers, which I change manually.
STEP 1
I CREATE THE PARTS LIST IN EXCEL AS WAS DONE BEFORE
STEP 2
i HIGHLIGHT THE REQUIRED CELLS AND THEN COPY PASTE THEM INTO MY AUTOCAD PAPER SPACE LAYOUT,
THEN SCALE THAT EMBEDDED OLE TO A SUITABLE SIZE TO FIT.
STEP 3
LABEL THE PART USING A MULTILEADER
STEP 4
CHANGE THE ATTRIBUTE TAG TO THE REQUIRED NUMBER
STEP 5
COPY THIS MLEADER TO NEW POSTIONS, DRAG THE ARROW HEAD TO THE REQUIRED PART,
AND CHANGE THE ATTRIBUTE TAG TO THE REQUIRED NUMBER AGAIN.
FINALLY I DO AN COUNT TO CHECK THE QUANTITIES, PUTTING A TICK ON A
NON PLOT LAYER TO SHOW MYSELF WHICH ONES I HAVE CHECKED
This is a very tedious,time consuming and prone to error method.
In my inventor drawings, balloon referencing and parts lists are automated and extremely easy to do.
There must be a better way in Autocad, which is sort of semi automated.
Possibly using attributes, listing the attributes in a table, linking the tag number to the attribute???
All my parts are inserted blocks.
I have never worked with attrubutes much before, have never had the need.
How do the rest of you tackle balloon referencing and parts lists in vanilla Autocad.
I know there must be a better way!!
Michael Kovacik
2d & 3d Autocad and Inventor designer/draughtsman
Draughting/Designing (Manufacturing) (31 yrs)
-Drawing Board (3 yrs)
--Cad (28 yrs)
---Cadkey (4 yrs)
---AutoCAD 2d & 3d (16 yrs)
---Inventor (4 yrs)
---Autocad and Inventor Simultaneously (4 years)
---(and recently Autocad/Inventor Customisation)
Autodesk Product Design Suite Ultimate 2018
Autocad 2018, Inventor Pro 2018
(personal licensed copy)
Johannesburg, South Africa
(Impossible only means you haven't
found the solution yet)
