Hello everyone.
I'm trying to print a sketch model generated in 3D space with AutoCAD (the image is made only of lines).
Despite I've tried any type of plot or export command, changing quality and DPI definition, I always have a bad-quality image.
share your drawing or show a screen shot of your PLOT window
@marco_gaetanidaragona wrote:Here I've attached the file. Thank you in advance
Thanks for the file. It's not quite clear what about your content (see your image) is not acceptable, are you trying to remove the color? Thicken the lines? Make those giant dots less observable?
I see you have assigned LWEIGTH settings to the objects, not layers, and they appear to be on the light end. See attached PDF: what's wrong with it for your needs?
The pdf file that you provided looks great. The problem was the definition of lines that resulted to be grainy.
Could you please provide me with the settings that you have adopted to obtain this pdf image? Thank you very much
@marco_gaetanidaragona wrote:...Could you please provide me with the settings that you have adopted to obtain this pdf image? ...
See attached
