Background Issue
Background Issue
jackzaph
Background Issue
jackzaph
Hi, I hit paper mode to change my background color for a print. However, I can now no longer change it back to the back background. I have tried options --> colors --> black but this does not work. AUTOCAD BACKGROUND ISSUE.JPG
cheryl.buck
Autodesk Support
Autodesk Support
Hi @jackzaph,
Check that you have the correct space selected in the Context list when you change the background color.
If a post answered your question or resolved the issue, please click the Accept Solution button.
Likes are always welcome.
All the best,
Cheryl Buck
Technical Support Specialist
Did a post answer your question or help resolve the issue? Please click the Accept Solution button.
If you find a response helpful, consider Liking the post.
jackzaph
Thank you for your reply, I did what was shown above. Still no change sadly
user181
Are you trying to change model or paper space?  If paper make sure you select Sheet / layout and Uniform background.
jackzaph
That worked thank you so much !
