Avoid dimension line supression
elisag23
elisag23
Hi, how can I avoid the supression of dimension lines? I am adding the height of windows and doors and when I move the text towards the middle the line gets supressed.
I've tried different options in the Fit tab of the dimension style manager but none seems to work
Thank you
paullimapa
Could you share the dwg version of your screen capture for everyone to take a look?
Paul Li
IT Specialist
@The Office
elisag23
Here it is 🙂
paullimapa
for those dimensions where you added a 2nd value below these are the steps I took to correct them:
1. DIMEDIT > HOME and then select those dimensions
2. Double click one at a time on each of those Dimensions or run the TEXTEDIT command
3. Replace current entries (or CTRL+A to select all) with: <>\X200
<> = dimension value
\X = value placed on line below
Now the dimension line shows up.
Repeat on the other dimensions
Paul Li
IT Specialist
@The Office
