Avoid dimension line supression
elisag23
elisag23
Hi, how can I avoid the supression of dimension lines? I am adding the height of windows and doors and when I move the text towards the middle the line gets supressed.
I've tried different options in the Fit tab of the dimension style manager but none seems to work
Thank you
0 Me gusta
Responder
Soluciones aceptadas (1)
228 Vistas
3 Respuestas
Respuestas (3)
paullimapa
Could you share the dwg version of your screen capture for everyone to take a look?
Paul Li
IT Specialist
@The Office
0 Me gusta
elisag23
Here it is :cara_con_una_leve_sonrisa:
0 Me gusta
paullimapa
Solución aceptada
for those dimensions where you added a 2nd value below these are the steps I took to correct them:
1. DIMEDIT > HOME and then select those dimensions
2. Double click one at a time on each of those Dimensions or run the TEXTEDIT command
3. Replace current entries (or CTRL+A to select all) with: <>\X200
<> = dimension value
\X = value placed on line below
Now the dimension line shows up.
Repeat on the other dimensions
Paul Li
IT Specialist
@The Office
0 Me gusta
