I would like to have a pdf automatically generated of everything I print in AutoCad. Autopublish seems like a decent solution, but isn't ideal as large assemblies I will wb out parts and batch plot without even opening the individual files. Is there a way to just have a pdf automatically made of everything I send to the plotter without having to run plot twice?
You need to use PUBLISH, and use DSD files to store the list.
Have you considered creating a .DSD file and batch plotting to PDF? You can make it publish in the background while you continue to work. Then just send your PDF to the plotter.
