i have to change my default save option several times a day, mostly between autocad2000.dxf and autocad2013.dwg. I figure a button on my toolbar would be preferable to options and dropdown selection each time.
i searched a bit and all i have seen was a command that no longer produces a result, "DefaultFormatForSave".
is there a way to make this slightly more simplified?
Solved by john.vellek. Go to Solution.
Solved by rkmcswain. Go to Solution.
Create a button with the following code
(setenv "DefaultFormatForSave" "60")
Replace "60" with the appropriate value.
"13" for 2000dxf
"60" for 2013dwg.
Hi @Anonymous,
Here is an AKN Article that shows the syntax for configuring the default SAVEAS formats. I think you could configure a button for both types using this method.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
