automatically closing polyline
bertbert
bertbert
I was wondering if there was a possibility to set a property to automatically close polylines.
Thanks in advance!
Best regards,
Bert
Accepted solutions (3)
tramber
Not really. But it is so easy do so during the creation or after.
  • Typing C (_Close) when drawing
  • Selecting them and going to the properties palette, it is easy to change their status, one of the last parameter in the palette, that you can change when you want. In a multiple selection, just apply the drop-down menu to select only polylines, if ever...
  • Last but not least, you can PEDIT, choose the Multiple and edit several at the same time by closing them, pleased to the option. Your selection will filter up the polylines inside any mix of objects. Practical.
Valentin_CAD
@bertbert ,
In addition to @tramber , you can also use or create a LISP for your intended purpose (sample below).
Consider the Visual LISP, AutoLISP and General Customization forum.
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
bertbert
Thank you very much for your answers!!!
I'll look into the LISP!
Have a good day!
Bert
