Automatically change rerence object for field display expression
So I am using text and multileaders which reads paremeters values of selected block through field display. I am wondering if there is any fast way to link new object to the existing field display label.
Alfred.NESWADBA
how about copying both objects, so the copied field should point to the copied base object.
(if I'm understanding the question correct)
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Thank for your answer. This could work for newly created block instances however - its highly prone to user mistake. I have a lot of complex blocks filled with parameters and now I am looking for easy solution to "tag" them on the drawing.
